Did a gig...Randall RM100
You sing better than Zakk :D
If I remember correctly you use the plexi module with a zw-44 overdrive. How much distortion are you getting from the overdrive vs. the module itself?
Dude, that was some wicked bls tone right there. Great performance btw, Keep it up!
Thanks for the comments!
That's right it's the pleximodule.. with a zw-44 infront of it.
Pedal setttings:
gain 2 o'clock, tone 12 o'clock, vol 3 o'clock
Plexi:
preamp 10, bas 10, mid 3, treble 6
I get pretty much distortion from the module it self, but I do need the overdrivepedal to make it scream..
But I use the Precence on the poweramp also to get some x-tra gain.
The Density control depends on what cab I'm using.. this time it was a standard 1960 Marshall cab.. they are not my favorite.
They can't handle the lowend the way I like it.
My main cab is an cheap Carvin 400w cab, very straight sound curve.. and very much in your face.
Also it does not distort the sound.. that I got an amp to do :wink:
