salvation
So, I finally finished my modification of CLEAN module.
It is called LoneClean and it is cloned after clean channel of Lonestar amp with a few features.
It includes TWEED mode, borrowed from Roadking 2 and TEXAS mode, which is my own variation of shimmery clean sound.
In Tweed and Texas modes this module is able to do nice crunch.
Central position is called LONE and it?s simply Lonestar Clean.
Added 2nd 3 position switch, borrowed directly from Lonestar, it has 3 positions: NORMAL , THICK and THICKER. It changes/adds mids- great for single note solo work. Thick and Thicker settings gives more "Plexi-taste" to clean sounds.
What more? Inside of module is little switch called WARM/COLD.
In WARM position this is Lonestar based sound.
In COLD mode sound of all settings is a lot cleaner and it is harder to break it up. Recommended for EMG users and users of hot pickups. This main mode is switchable only when module is out of the slot.
Congratulations to Crankyrayhanky for his new sounds! :wink:
simple soundsample is here:http://soundclick.com/share?songid=7810061
