LED strips inside a guitar amp head
lolthrash
Australia
I think I've read people talking about it on here before, but I can't remember where I saw it and I can't find it... But has anyone wired a bunch of LEDs inside your amp head to light it all up? Curious about how you would go about running them off the amp's power supply..
Thread discussion and some good info/pics here:
http://www.mtsforum.grailtone.com/viewtopic.php?t=275&postdays=0&postorder=asc&start=255&sid=9f21a622cd955de7f274d09e1158004f
from what i understand, get two 24" aka 60cm led strips with self adhesive tape on the back. put one on the top and one on the bottom just behind the grill. wire it into the fan which should be 12v
schladog should be able to clarify
see here for an example, or just go to ebay and type in 60cm led strip
http://cgi.ebay.com/ebaymotors/NEW-RED-LED-60cm-Waterproof-STRIP-Ribbon-Flexible-Under_W0QQcmdZViewItemQQhashZitem56362464cfQQitemZ370275542223QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
lolthrash said:
I think I've read people talking about it on here before, but I can't remember where I saw it and I can't find it... But has anyone wired a bunch of led light inside your amp head to light it all up? Curious about how you would go about running them off the amp's power supply..
hello friend sorry for old thread reply but have you wired bunch of led in an amp? Please share your experience as i am working on similar project
https://solarlifesolutions.ca/solar-panel-maintenance/
Hello,
The question was, with the LED stips, all it has is 2 open wires, where do they connect to, or do they connect to the halo lights connection????
