TOP BOOST BRIGHT TWITCH
motokev
There is little difference when switching the bright switch on or off on my TOP BOOST module. All my other modules, the BRIGHT switch has great contrast. TOP BOOST owners please let me know if your BRIGHT switch makes any difference. If so, what would you think is wrong with my BRIGHT. THANKS[/b]
The bright swich's effect will vary depending on how high you have the gain turned up. It essentially works like a gain bypass swich for the high end (high end bypasses the gain knob). So if you have the gain knob maxed out the bright swich will not do anything.
