Switching from clean to boosted overdrive channel on T2
Mephisto
I am interested if there is the possibility to switch from clean channel directly to boosted overdrive channel. I mean if you are on the clean channel and press the boost button on the pedalboard, does the and switch on ther boosted overdrive mode? Or if there is another way of switching directly from clean to boosted overdrive.
Do you have the pedal? On my T2 pedal there is a button for the 3 different channels, so yes you can.
