RG-80ES Power Switch
brianm99
I just bought a Randall RG-80ES and the power switch broke off. Is replacing this an easy process?
Which replacement switch will work?
should work fine as long as the jack on the amp is fine...
http://www.championpedals.com/fs5j.htm
http://voodoomanswitches.com/component/page,shop.browse/category_id,16/option,com_virtuemart/Itemid,1/vmcchk,1/
He's talking about the Power Switch, not FS..
How did you manage to break it anyway? :lol:
You need one of these, it's easy to replace btw..
This weekend I just bought an on-off-on switch at Radio Shack for $3.99 but had to buy crimp on connectors for $1.99 since the unit has a screw in each leg and you can't solder onto the material the tab is made of.
Works great! Nice and sturdy!
A hair longer than I would have liked (touches the ground or table if I lay it on it's face) but a bit shorter than the POS plastic switch that someone had replaced it with prior to my trade. I guess I could always dremel off some of the tip if it were a real issue for me.
