Tweaker question
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Egnater Amps
Anomaly
PostPosted: Wed Aug 04, 2010 4:42 pm    Post subject: Tweaker question Reply with quote
Got this little 15 watts Amp a couple of weeks ago, Love it!!! Question, is this amp fixed bias? which power tubes could be used on this amp? where can I find info on the preamps V1-V3? thanks!
Buckeyedog
PostPosted: Thu Aug 05, 2010 8:57 am    Post subject: Reply with quote
Bias terms are funny. Fixed bias means you actually have to adjust the bias. Cathode bias is where you just plug and play. The Tweaker is plug and play and you can use 6l6's and EL34's and probably some other octal based tubes like a KT77.
The manual should have pre amp tube stuff. Check out Egnateramps.com and maybe there is some info there.
Anomaly
PostPosted: Thu Aug 05, 2010 2:51 pm    Post subject: Reply with quote
The manual doesn't say anything about the tubes both preamp & power.
So I could just plug any octal(?) based tubes? how about el84?
Buckeyedog
PostPosted: Fri Aug 06, 2010 10:20 am    Post subject: Reply with quote
EL84 is nine pin, so no go. Unless you get some Yellow Jacket converters.
Pre amps are basically V1 is closest to the input jack. The PI is closest to the power tubes. Just have fun swapping those around.
m0jo
PostPosted: Sat Sep 25, 2010 5:57 pm    Post subject: Reply with quote
These things always make me wonder: why aren't all amps auto biasing?
(with maybe the option of tweaking how hot/cold it should be)
I guess it is technically challenging, otherwise it would've been done.
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
withmittens
PostPosted: Tue Apr 25, 2017 11:17 am    Post subject: Reply with quote
I think the 15 watt is 6V6 and EL84, no? was thinking about picking one up. Is it awesome?
RM22, RM4
CrazyNuts' Dirty Sanchez, DuoPlex, Selma, Supra, Twinface, Evil Kitty, CC30, XTC
SG, LP Std., Strat
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Egnater Amps All times are GMT - 6 Hours
