i do it meself
Goto page 1, 2  Next
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods
guitarmanscott65
PostPosted: Sat Aug 07, 2010 6:17 pm    Post subject: i do it meself Reply with quote
i have a blackface i dont use and i want 2 mod it myself.i would like to get a little distortion,but i dont know wich Rs and Cs to change.would anyone b so kind as to piont me n the rite direction?
you can tuna piano but you can't tune a fish
View user's profile Send private message Send e-mail
eedude
PostPosted: Thu Sep 16, 2010 10:46 am    Post subject: Reply with quote
i suspect this is in the wrong category... Moderators is there a better place to move this to?
to get more gain look at the attenuation between 1st and 2nd stage on the module. I don't have a blackface schematic, but I'll bet it's similar to the Clean. So on the clean it's R26 and R28, check your board measure those two r's and lets see what value they are...
Good Deals w/ randall3, cold Machine, El Dangerouso, tonelover, Seano, jitterybit, alowerdeep
Prog for all: http://www.myspace.com/onyxguild
m0jo
PostPosted: Thu Sep 16, 2010 3:09 pm    Post subject: Reply with quote
First off you'd need to start using proper language, with this "2" and "rite" you seem like a 12 year old.
No offence meant, just constructive cristicism.
On the grailtone.com website there are some mods that are pretty well documented.
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
guitarmanscott65
PostPosted: Wed Sep 22, 2010 4:24 pm    Post subject: Reply with quote
27 is 2100000.....28 is 220k....so whattia think? and thanks FOUR responding you guys!I've had my rm 100 four several years now,and love it.
eedude
PostPosted: Wed Sep 22, 2010 5:58 pm    Post subject: Reply with quote
so that's 2.1M and 220k which make one hell of an attenuator.
I would put maybe a 1M or a 470k across the 2.1M. Note that if you do that the module will get louder as well and have a little bit of a tone shift due to C10 (i would expect a little less high end).
I have no idea how 'good' this mod will sound but you will start to overdrive V2.
guitarmanscott65
PostPosted: Tue Sep 28, 2010 5:02 pm    Post subject: Reply with quote
I like the idea of less treble.All my gtars have wammys,so that might be just right.thanks.i'll give it a try.
eedude
PostPosted: Wed Sep 29, 2010 10:45 pm    Post subject: Reply with quote
.. you could even pull out c10 and see if you like that then.....
guitarmanscott65
PostPosted: Sat Oct 09, 2010 4:34 pm    Post subject: c10 Reply with quote
DUDE! you nailed it with 470k.perfect on the "breakup" part of it.now, could you tell me a bit more about the funkshun of c 10 ?I'm looking for a fuller more robust sound.he he he i said bust.
eedude
PostPosted: Sun Oct 10, 2010 5:35 pm    Post subject: Reply with quote
C10 allows high freq to bypass the attenuator. You may want to take it out and see how you like the sound.
Also for a little more poop, you can put a 1uF in for C7 (i think it not populated right now.
guitarmanscott65
PostPosted: Sat Oct 16, 2010 1:16 pm    Post subject: nob Reply with quote
just curious, is there an easy fix to get my volume nob back from 8 or 9 to about12 or 1:00?
eedude
PostPosted: Sat Oct 16, 2010 5:34 pm    Post subject: Re: nob Reply with quote
i'm not sure i understand.... is it that with the mod you need to turn down your master to ~8 where is was at ~12 before the mod?
Shinozoku
PostPosted: Sun Oct 17, 2010 8:13 am    Post subject: Re: nob Reply with quote
Turn it clockwise 90 degrees.
RM100M w/ Tung Sol 5881's
Blackface(self modded), Ultra Lead, SL+(out of commission), Ultra XL (self modded)
Vader 2x12 Cab
Edwards E-AL-128 with a Seymour Duncan JB
View user's profile Send private message MSN Messenger
PostPosted: Sun Oct 17, 2010 9:46 am    Post subject: Re: nob Reply with quote
Laughing
guitarzan
PostPosted: Mon Oct 18, 2010 5:49 pm    Post subject: but..... Reply with quote
Which one is the any key? Razz
guitarmanscott65
PostPosted: Sun Oct 31, 2010 3:48 pm    Post subject: Re: nob Reply with quote
yes
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
