RM1250 (12 channel) MTS amp is here!
www.funkymunkymusic.com
Shawnee, KS
$1399 unloaded
$2499 loaded!
the first run come with chrome face plates on the loaded models
IN STOCK AND READY!
Looks like you'll need a midi controller to use it efficiently. Front shows one button for cycling through 12 presets, no fun.
we just got ours in. I think funky monkey will agree, this thing is pretty cool.
it comes with a midi foot controller
1-4 5-8 9-12
so if you miss the one you want, you are only 3 away...
I just got the one for store demo Randall hit a home run with this one.
Nick
I still link 3 RM4s so I can use my Rt2/50...Randall almost had a hit with this one but there's no real way to bypass the 50 watt power amp...It should have been a built in 2 Channel power amp...Big mistake IMHO...
kc2eeb said:
What if you just pull the output tubes?
If I'm not mistaken I was told by funkymunky awhile back that there was no true bypass of the power amp...I guess pulling the tubes would effectively cut the influence from the power tubes and will need another source...I just don't know how much it colors the tone in the power amp...It could be insignificant...But then you're dropping cash on a useless power amp... :(
My best guess is that the effects send level will give you what you need to
drive the RT2/50. I agree that 2 (or3) RM4s will give you more versatility,
but if you had no RM4s, it might be interesting.
