Issue with 1989 Randall RG100ES
sAvAgE
I seem to be having an issue with my Randall Amp. I am the original owner of the amp and this is the issue I am having.
From other communities it seems to be a known issue. just wondering if there is a known fix to rectify the situation. There seems to be a Channel leak on the amp.
Here is a Video Demo Explaining what the issue is
here is the vid if you need more information on the issue that is happening I can do another demo
http://68.150.160.253/
I am also having a LEAK problem.
I just bought a fs-5 foot switch,
I can have clean on with no PROB.
but once I hit the switch I get OD and Clean together
OBVIOUSLY this is NOT GOOD
has anyone given you solutions????
PLEASE HELP!!!!!!
I did find this link
seems to maybe solve the issue
http://home.earthlink.net/~marcelroy/gear/ampsfx/86randall.html
but if anyone else has solutions
PLEASE HELP!!!!
I took my rg100es in to be cleaned a few years ago and was told the leak is normal for this model.
Once I got my foot switch, it practically disappeared.
Now, yesterday on the Dean forums, someone said that as long as you keep the six pin connector for the foot switch clean it is less noticeable. He goes into great detail about it.
Here is the link:
http://www.deanguitars.com/forum/viewtopic.php?t=43346
Oddly enough, I found that link Googling how to clean rack gear.
Hope this helps :) [/url]
i read this, but not sure if that really helps since he doesnt say how to do it.
http://mtsforum.grailtone.com/viewtopic.php?t=8233&highlight=daughter+board
The 6 pin footswitch wears out over time. A few people I know with this amp had to replace the 6 pin on the amp and footswitch in order to correct the problem with bleed over. That piece is hard to find but at least one company still sells those parts. They are a few dollars each.
At the bottom he updates and says that he thinks the problem is a wire quality issue.
I just traded for a RG80112SC and noticed that with the footswitch plugged in it was dropping the sound intermittently just a bit, but no problem without the footswitch and so was looking at wiring up my own cable (that can be shorter than the original).
I will definitely look into cleaning it first and also checking to see that both plug and jack don't have any issues like being spread too far apart or shorted wires at any ends.
I have a KMD 60 that has a hardwired footswitch so that also is another option since it works, just need to make sure and use the proper strain relief after cutting another hole or fixing a plate with a hole and strain relief to cover the rectangular hole where the jack is now...
