Pete Brown mod with .0047 cap at C3?
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods
Ricey
PostPosted: Sun Jan 09, 2011 9:41 am    Post subject: Pete Brown mod with .0047 cap at C3? Reply with quote
I won a modded Brown Module in an EBay auction. The guy said that it was a Pete mod, except that he went back to a .0047 cap at C3 because he preferred a fuller bass response. I am wondering if I should switch back to the .0022 cap? I run a graphic EQ in the effects loop of my amp and I do have the bass slider set for a small boost. The module sounds great, but if I turn the bass all the way up with the gain maxed, the stock Celestions in my RM-100 start to fart out a little. I also have Plexi, SL+, and Ultra XL modules and I can turn the bass knob all the way up on those modules and also boost the bass on the graphic EQ under high gain conditions without this "farting out". My solution for the Brown is that I have to keep both the gain and bass down to 3:00 or lower or not use the EQ boost. I am assuming the .0022 cap would help with the farting out, but how would it effect my tone otherwise? I do prefer a full bass response.
okstrat
PostPosted: Mon Jan 17, 2011 1:13 pm    Post subject: Re: Pete Brown mod with .0047 cap at C3? Reply with quote
I put a smaller bass cap there on my brown mods for two reasons:
1) less 'fart out'
2) Ever listen to Van Halen I or II? Not a lot of low end on those tones...
Pete
Ricey wrote:
I won a modded Brown Module in an EBay auction. The guy said that it was a Pete mod, except that he went back to a .0047 cap at C3 because he preferred a fuller bass response. I am wondering if I should switch back to the .0022 cap? I run a graphic EQ in the effects loop of my amp and I do have the bass slider set for a small boost. The module sounds great, but if I turn the bass all the way up with the gain maxed, the stock Celestions in my RM-100 start to fart out a little. I also have Plexi, SL+, and Ultra XL modules and I can turn the bass knob all the way up on those modules and also boost the bas on the graphic EQ under high gain conditions without this "farting out". My solution for the Brown is that I have to keep both the gain and bass down to 3:00 or lower or not use the EQ boost. I am assuming the .0022 cap would help with the farting out, but how would it effect my tone otherwise? I do prefer a full bass response.
New Gigmods webpage!
PostPosted: Mon Jan 17, 2011 2:08 pm    Post subject: Reply with quote
Yep...You'll get a tighter response from the 22...Less bass, more focused...It will likely be a significant improvement especially if you have too much bass on it now anyway...You could even drop a 11 in there for ultimate tightness... Smile
Ricey
PostPosted: Tue Jan 18, 2011 10:55 am    Post subject: Reply with quote
Thanks, that's what I thought! I'll have it converted to the .0022. I wonder why did Randall put the .0047 in there in the first place?
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods All times are GMT - 6 Hours
