salvation
New addition to Salvation Mods.
DUOPLEX module
based on Marshall 1959 Plexi amp.
Why DUO plex?
This module uses new and unique option of BLEND two channels together.
It works in the same way like the old trick used often on Plexi amps - with two channels "bridged" together by short cable.
Module is equipped with separate Gain controls for High Treble (equipped with Bright switch) and Normal flat - bassier sounding channel.
So, you can play on Bright channel, or Normal channel, or blend them together. In this way you can dial bright plexi tone and add some bottom from Normal channel, or vice versa. Using this technique, you?ll be able to take advantage of using both of the Duoplex?s channels at the same time.
- In addition it uses STACKED mode, which switches these two channels in SERIES. In this mode it works like famous "one wire mod" used for example on Randy Rhoads signature 1959.
In STACKED mode both Gain controls are active in series and it offers variety of tones from staurated crunch to nice fat and juicy higain tone.
- Added VOICING option already used on Mash-All module, with JTM/JCM voicing options.
Clip:
http://soundclick.com/share.cfm?id=11115425
some pics:
DUOPLEX module
Why DUO plex?
Clip:
some pics:
