Randall experts,
I have the RG100es and bought a FS-5 switch from Switch Doctor. It works. But the one issue is that the red channel LED doesn't turn on ON BOTH THE AMP OR THE SWITCH when the channel is switched on by itself or when both channels are running at the same time. I contacted the maker of the switch and he said that the voltage from the amp dictates the lightening of the LEDs. I thought originally it was the bulb in the amp but both lights aren't working on the amp and footswitch.
My question is if anyone has had this experience or if it makes sense, and if contact cleaner may work? Or does this require a new component or repair by a tech? Any help would be appreciated. Thanks,
Pierre
Pierre
