Orren
Hi all,
I wonder if one of you who owns or has owned the Randall RT2/50 Power Amp can answer a question for me about it's channel switching mode.
From what the Randall website says, I understand that you can plug your preamp into channel one input, a speaker cabinet into channel one output, and a speaker cabinet into channel two output, and then switch between them. This way, you can have one preamp (in my case, it will be the Egnater M4) and switch it between two different power amp/speaker combinations.
But...
Is it possible to use one preamp and only one cabinet, and switch channels of the power amp, but keep using the same speaker cabinet?
Or would you need some sort of 2 amp/1 cabinet switcher?
Orren
But...
Orren
