bruce egnater
I have recently designed a small box to adapt high level loops (Egnater Modular/ Randall MTS, etc) to work with any pedals. It is powered with an 18 volt wall wart (no battery), has in/out/send/return jacks with send and return levels. Easily solves the pedals in the loop issue once and for all. Could also be used to insert pedals between a preamp and poweramp.Planning to produce a small number of them that will sell direct for around $150(USD). I wan't to get an idea of how many to make before ordering parts, boxes, boards etc. Also would allow you to mix line level/rack gear with pedals in the same loop simuntaneously. Any interest?? Should be available around mid May.
email me to get on the list.
[email protected]
[email protected]
