FX loop
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps
Teraphim
PostPosted: Fri Jan 12, 2007 12:14 pm    Post subject: FX loop Reply with quote
What is the effect loop, and how do i use it? I've never been into this stuff before...
View user's profile Send private message MSN Messenger
Scooter
PostPosted: Fri Jan 12, 2007 12:21 pm    Post subject: Reply with quote
I don't know which amp you have but...
On the back of your amp is an input and an output jack labeled FX Send and FX Return. It is basically a signal path from the preamp to the power amp.
Time based effects and EQ's work well here in my opinion.
Plug the SEND of the loop into the INPUT of your effects, and plug the OUT from your effects into the RETURN of the loop.
(Is that what you were asking?)
twistedgraffix
PostPosted: Fri Jan 12, 2007 4:30 pm    Post subject: Reply with quote
The preamp makes your sound and the power amp adds the volume for the most part. Some effects do better after the distortion is put into the sound than before like scooter said. Experiment.
Teraphim
PostPosted: Fri Jan 12, 2007 5:04 pm    Post subject: Reply with quote
I have a RH150G3. Thanks alot!!
JJLeo77
PostPosted: Sat Mar 10, 2007 6:12 pm    Post subject: Reply with quote
So, in your opinion where would one put a noise gate? In the effects loop or out front?
TheAbomb12
PostPosted: Sat Mar 10, 2007 8:34 pm    Post subject: Reply with quote
Serial Effects loop. Unless your distortion comes from pedals- in which case, it should be the last pedal in the signal chain.
ESP/LTD EC-1000
Ibanez RGT42DXFM (Seymour Duncan Blackouts)
Maxon OD808
TC Electronics G-major
Framus Cobra V2
Cobra 4x12 Slant Cabinet
Hughes and Kettner CC412B (Greenbacks)
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps All times are GMT - 6 Hours
