Ground control Pro And RM100
reilly
Lancaster, PA
Can i use the Ground Control to channel switch my Rm100? If anyone is using this setup id like to see some pics, i want to use the PODxt for my effects. Im trying to build a fairly simple rig that will have a lot of diversity. Ii am open to suggestions. No one in my area that i know of is running a rack of any sort.
thanks
I use the old Ground Control with my RM100C and I'm sure the G.C. Pro will do just fine. Your RM100 is probably set to channel 16 and the presets are 1,2, and 3 for each channel. Set up your controller for those specs and you should be in business. The Ground Control is nice becuase you can assign different devices to each button, so you can change to, for example, preset 1 on your amp and preset 12 on your effects with one switch if you want.
Cody
ok thanks man, im really stoked to get the G.Control, I think it will help me utilize my amp to its fullest potential.
