Randall Warhead input jacks
grb31
Hi all,
I have a 150w Warhead combo and the input jack sheared off just past the faceplate.
After a closer look, I've also noticed that there is some damage to the chip that this is soldered onto, and the plastic housing that the jack slots into. The guy that had this before me must have had issue with it and tried a botched repair.
I was wondering if anyone could help with the name/serial of the part, and where I could order one from the UK? I need to replace the entire unit basically, the input jack, plastic housing and the little chip that the whole shebang sits on that is wired to the main amp board.
I tried looking for input jacks on ebay and that and I can't find anything remotely similar.
Cheers folks
-G
[edit] I should add I did once try getting info from customer support but never heard anything back...
