RT503 HELp PLEAAAAASEEEE EASY NOOBISH QUESTION
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps
raed666
PostPosted: Thu Jul 05, 2012 11:40 am    Post subject: RT503 HELp PLEAAAAASEEEE EASY NOOBISH QUESTION Reply with quote
Hi, I have randall RT503H And would really appreciate your help on this, What is the preamp tubes schematics for this head, I want to use the power amp section with an external preamp, bypassing the head's preamp section using the 4 cable method, the thing is i need to know whcih of the 5 preamp tubes are the phase inverter and the FX preamp tubes, just to remove the other 3 tubes for the Ch.1,Ch.2,Ch.3,,,just not to end up with dead preamp tubes in the head (will this also may hurt my amp)?? Much Thanks!!!!!!
Rod
PostPosted: Sun Sep 30, 2012 1:59 pm    Post subject: Reply with quote
Don't pull out tubes you are not going to be using....
www.freighttrainband.com
www.rodwelles.com
View user's profile Send private message Send e-mail Visit poster's website
zepplin490
PostPosted: Sat Jun 29, 2013 8:30 pm    Post subject: Reply with quote
You dont need to use the 4CM or frig around with the tubes to bypass the preamp and use it as a power am just run the output of your preamp into the loop return and you'll be good to go, Ive used my RM4 through a bunch of different amps this way.
-MP-
Randall RM100, with a Randall Warhead V30cab,
Voodoo UG Jose
Good Deals With: Everyone
View user's profile Send private message AIM Address
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps All times are GMT - 6 Hours
