Judge mod volume difference?
Post new topic   Reply to topic    MTS Forum Forum Index -> Signature Artist MTS Models
Boogieman5150
PostPosted: Wed Mar 06, 2013 9:13 am    Post subject: Judge mod volume difference? Reply with quote
I just got a judge module and its considerably quieter than my other modules. Is this normal? If not, any ideas why? Thanks
Live rig-Bogner Ecstasy 101b
studio- Randall RM20
Too many guitars to list!
Kapo_Polenton
PostPosted: Wed Apr 03, 2013 8:09 am    Post subject: Reply with quote
Yeah i found that as well but it wasn't drastically different. Are you referring to the second toggle switch or right out of the box toggles both to the left?
PostPosted: Wed Apr 03, 2013 8:35 am    Post subject: Reply with quote
Some mods filter in different ways and produce varying degrees of output...While most mods tend to be around the same output, some (such as the Afterlife) need a big bump on the module master volume to match the others- totally normal and expected...
Hamner1
PostPosted: Fri Apr 05, 2013 2:56 pm    Post subject: Reply with quote
On the stock Judge I had, Mode 1 was comparable to the other mods I had, but Mode 2 was definately lower volume with the moule Master set the same. But the differenc was not that significant. If I had Mode 1 set at 10:30 o clock, I wouldn't need to move the Master past noon to achieve the same perceived volume.
Non-MTS stuff for sale.
Good deals with: warlock, sickpunk, marinebassplayer, Rising Farce, durchgedreht, mattfig, & others.
notyet
PostPosted: Wed Oct 02, 2013 9:15 am    Post subject: Reply with quote
I notice it being quieter with the mode switch but its not a problem so far. I usually run the modules at 12 o'clock and the judge needs to be a little higher than that. I really like that voicing though.
WienerDog
PostPosted: Tue Oct 22, 2013 2:37 pm    Post subject: Reply with quote
My experience is similar to what notyet says. My Judge with the master volume at about 12:30 is equal to my Brahma with the master volume on 12:00 noon. Also, mode 2 on the Judge is slightly lower in volume than mode 1.
Post new topic   Reply to topic    MTS Forum Forum Index -> Signature Artist MTS Models All times are GMT - 6 Hours
