GSP 1101 vs G-Major2
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Gear
walshinator666
PostPosted: Mon Oct 13, 2014 6:23 pm    Post subject: GSP 1101 vs G-Major2 Reply with quote
I looking to buy a new effects processor and am having trouble deciding between the 2.Anyone here use either one.I know the gmajor has a boost feature but does the 1101.This could be the deciding factor.Thanks
RM4,RT2/50,RM50,JF superclean, JTM45,JF Rebel,venom
GOOD SALES with flying v , tlingen, the hunter,salvation,crankyrayhanky,cold machine,JFaithX2,Langseth and alowerdeep
GOOD TRADES with stratomaster, schlagdog,speedemon,mattfig and mfred
Nightdare
PostPosted: Tue Oct 14, 2014 1:32 pm    Post subject: Re: GSP 1101 vs G-Major2 Reply with quote
If I were to compare the 2 for versatility, the 1101 easily wins because of 3CM ability, allowing Pre And/Or Post FX
the Gmajor2 Manual does not mention a boost, only an EQ (which the 1101 also has, and that can be moved before, or after the preamp)
and a simple volume boost can easily be attained by upping the unit's output volume
As for fidelity, I'm not sure, the 1101 isn't an Eventide, but the Gm2 isn't TC electronics best effort either
(Yes TC is renowned for some fx, but Digitech owns Lexicon, you're getting next gen MPX G2 tech in the GSP line)
For sound, I'll bet they score about the same
tschrama
PostPosted: Tue Oct 14, 2014 2:37 pm    Post subject: Reply with quote
I know nothing of the 1101..
but I have a older Gmajor, version1... I would choose the Gmajor if only for the build in tuner and noise-gate, and excelent ergonomics.. it's soo easey to program.
very curious about the 1101, I hope more people can reponse. You might also check rigtalk and gearslutz
my small atelier called 's-Gravenmade | Follow me www.sgravenmade.com | Join my Amp Building Workshop 14 april 2018
Good deals with: C2ply, BenMesaBoog, YouguitarHero, nitrous12, kylendm.
View user's profile Send private message Send e-mail AIM Address
walshinator666
PostPosted: Tue Oct 14, 2014 9:54 pm    Post subject: Reply with quote
I saw a you tube video on how to use the boost feature.Hmmm what to get??
Corium_AZ
PostPosted: Tue Oct 14, 2014 10:19 pm    Post subject: Reply with quote
I recommend doing a search of this forum. I've looked into this in the past, and there is a plethora of opinions on both...
Band Sites (Until The Sun)
http://www.reverbnation.com/untilthesun
https://www.facebook.com/UntilTheSunBand
Budda Superdrive 45, Orange Rocker 30, Zinky 4x12, '72 Deluxe Tele and MIJ Greco LP Custom
ned
Site Admin
PostPosted: Wed Oct 15, 2014 9:55 am    Post subject: Reply with quote
I have both. Get the 1101. The Gmajor is a great piece of gear but the 1101 is much easier to use and get great sounds.
Grail Tone - Amp Settings
My Rig: Egnater Mod 50 1x12 Combo w/ VX and SL2 modules
FX: Digitech GSP1101, RM4 w/ SuperV, JTM45, Plexi, XTC, KH2, TB
Personal Web Page
tschrama
PostPosted: Wed Oct 15, 2014 1:13 pm    Post subject: Reply with quote
And it's cheaper than the Gmajor2 too..
check this out:
http://www.youtube.com/watch?v=4KGIiARYcNs
LarsTurms
PostPosted: Sat Dec 27, 2014 11:15 pm    Post subject: Reply with quote
GSP1101 pros (assume C63 firmware):
-4cm
-transparent!
-easy and straight forward settings
-Control 2 (powerful tank built midi controller via 1 cable with huge lcd and awesome tuner)
-10 user cabinet impulse responses (!!!)
-2 LFO's (I believe Gmaj only has one but not sure)
-modelling (may not be your thing but it's always handy as a backup, or practice tool, Vox AC30 simulation sounds like Matchvox on low gains so I ended up using the simulation for cleans and now the Matchvox can be gained up to Brian May kind of sound. I also use 5150 simulation for practicing and messing around for long periods of time when I don't feel like burning the tubes in my rack.
-works really well as audio and MIDI interface with the iPad (via camera kit adapter). I use this mainly for practicing and composing (can play backing tracks from iPad, I can tap tempo metronome on my Control 2, use Loopy looper app and control it via the Digitech FS300 footswitch, record in Garageband etc.)
-noise gate can do the ISP decimator pre/post kind of thing (you may have to google this for details)
Cons:
-doesn't have relay for channel switching as Gmaj
-fairly limited changes in the effect chain - few effects have pre/post settings but that's about it
-only one modulation effect at a time (you can have reverb, delay, wah, distortion and chorus altogether but you can't have chorus and flanger together or ring modulator and whammy together)
-not very good for crazy, psychedelic, experimental etc effects, it's quite conservative although the lfo's can be assigned to control pretty much anything
- doesn't have input in the back
- had to borrow Win laptop to update firmware as the SW didn't work on Mac
kc2eeb
PostPosted: Sun Dec 28, 2014 8:02 am    Post subject: Other Gear Reply with quote
https://www.youtube.com/watch?v=tyBUMntP6DI
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Gear All times are GMT - 6 Hours
