Going in a different direction, and have the following for sale. Will send pics if you provide an email -
RM100 head in an egnator cabinet. Upgraded MM transformer and choke. Tung sol EL34 tubes with low mileage. One issue, easily fixed - one of the bias knobs has fallen back in the chassis after adjustment. Just needs to be put back.
$600 shipped to lower 48 only.
Sacred Groove MK22 module in very good shape. Well known here as one the best plexi mods. $225 shipped.
Super lead module - custom made by Jaided faith, with custom face plate. This was built from a stock SL+ module, with a three way tight switch. The bright switch is now a gain boost. There is also a mid sweep knob. The treble pot is a less bright sound - the same treble value as the MK22 and the KH3 module. This module will give you a smoother, midrange type of overdrive. In great shape. $250 shipped.
Any questions let me know. Will consider a package deal.
Thanks
Thanks
