ISP Decimator in RM100 Loop?
Goto page 1, 2  Next
Post new topic   Reply to topic    MTS Forum Forum Index -> Rigs & Tones
nitrous12
PostPosted: Thu Apr 09, 2015 7:59 pm    Post subject: ISP Decimator in RM100 Loop? Reply with quote
Can the Decimator or Gstring pedals be used directly in the loop w/out a level shifting device?
Modules: JF SL-OD100, JF Super Clean, JF Voxless, JF PlexiTweed, JF VHT, JF Custom Erect, JF Silverado, Salvation Stonerverb DeLarge, SG XTC LE
PostPosted: Thu Apr 09, 2015 8:51 pm    Post subject: Reply with quote
The pedals cannot, the rack versions can...
nitrous12
PostPosted: Fri Apr 10, 2015 6:02 am    Post subject: Reply with quote
Man that sucks. I recently got a STEP pedal but really just wanted it for the boost. So now if I need noise reduction in the loop I need to also add a different boost. It never ends.
Jaded Faith
PostPosted: Fri Apr 10, 2015 6:27 am    Post subject: Reply with quote
Interesting note: I use a Decimator pedal as my benchmark for designing and testing effects loops. If you don't clip one of these with your send level then nothing will clip. Super sensitive.
www.jadedfaithmods.com
https://www.facebook.com/JadedFaithMods
Email: info@jadedfaithmods.com
Authorized Service Center for US Music and Egnater
Authorized Reseller for Celestion, Scumback & Mercury Magnetics
View user's profile Send private message Send e-mail Visit poster's website
PostPosted: Fri Apr 10, 2015 8:42 am    Post subject: Reply with quote
The Decimater was the last hurdle on my pedalboard when Rob was designing and testing the STEP. The original "little black box" worked perfectly until the Decimator was introduced in the loop, then all hell broke loose. The STEP will quell any Decimator issue.
MarcoR
PostPosted: Fri Apr 10, 2015 11:28 am    Post subject: Reply with quote
People need to stop trying to put toy boxes in line level loops designed for pro level gear... Wink Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile Smile
running and ducking for cover
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
PostPosted: Fri Apr 10, 2015 11:31 am    Post subject: Reply with quote
The call him MarcoR, Danger Seeker
nitrous12
PostPosted: Fri Apr 10, 2015 12:09 pm    Post subject: Reply with quote
I know but if I put it through the STEP in the loop I would need to leave the STEP on full time and I lose the volume boost ability of it. Would need to add another pedal for boosting. Good news on that though is I could use anything again and not have to worry about it not liking line level.
My rig has been quiet at rehearsal but I know that can quickly change when you get on stage. Just don't know yet if I will need loop noise reduction or if doing it out front will suffice.
audiomidijace
PostPosted: Fri Apr 10, 2015 4:00 pm    Post subject: Reply with quote
What other pedals are you using in the FX loop?
RM50, Orange PPC412 w Celestion V30s.
Modules: SG-MK22, JF Twox .
Pickups:MotorCity & BareKnuckle
Dunlop 95Q Wah, TC Nova System, Wampler Tumnus
AVID ELEVEN RACK & Atomic Amplifier 12
Transactions:Lots!
suphuckers
PostPosted: Fri Apr 10, 2015 4:02 pm    Post subject: Reply with quote
yeah I agree Marco, except I still go back to the effects in the "toy boxes" are sometimes better than other "pro" gear. That doesn't so much apply to trying to smash a decimator in there tho LoL
"Dude, you're easily the gnarliest guy I've seen around here in years"
59' Sears Wish Book Cowboy Guitar w/ Christmas Box, AXL Acoustic Guitar Pickup w/ E-pin Jack, Marshall MS-2 1/2 Stack Classic. ohhh, and some modules.
nitrous12
PostPosted: Fri Apr 10, 2015 7:06 pm    Post subject: Reply with quote
None. I just have the STEP there now in boost mode. I could see a delay at some point but don't have or need one right now.
suphuckers
PostPosted: Sat Apr 11, 2015 5:04 am    Post subject: Reply with quote
nitrous,
Have you tried just putting the Decimator in front of the amp?
That's probably where it should be. Idea
Jaded Faith
PostPosted: Sat Apr 11, 2015 5:16 am    Post subject: Reply with quote
The key to using a gate properly is to determine your needs and what it is that you are trying to gate exactly.
A noise suppressor should sit right after the noise source you're trying to deal with. The more stuff you add before it (or between the noise source and the noise suppressor), the harder it will be to get a setting that kills the noise without messing with the note decay and overall tone.
For starters, you need to figure out where the most noise is generated. If it's when you use the amp's distortion channel, running the noise suppressor in the loop will be the only way for it to touch that noise. However, you will then need to find a compromise setting that works for when you're using the clean channel or the clean channel + dirt pedals.
Conversely, if you find that the amp's distortion channel is relatively quiet while the pedals or guitar are the source of noise, the noise suppressor will be better placed in front of the amp.
Do the noise tests with the guitar volume off and compare with the guitar volume turned up. Noise from the guitar (pickup hum, feedback, etc) is usually better dealt with at the source.
In general, it depends on how you want to use it.
1. Do you have excess noise/hiss from having a lot of gain? Use it in the FX loop. This is the "hard stop" method that a lot of metal guys like. I always think of Static X as an example.
2. Do you just need help against feedback or general environmental noise that is being picked up via your guitar/cables/pedals? Put it in front. This is my favorite application and far more gentle and musical. If you still want max sustain and notes to be able to bloom into musical feedback with minimal jitter or lost tails, go this route.
nitrous12
PostPosted: Sat Apr 11, 2015 5:23 am    Post subject: Reply with quote
suphuckers wrote:
nitrous,
I don't have one yet. I am just in the process of building up my rig for gigging again, which is why I was asking before I buy.
I have run decimators in the past and have used them both in front or in the loop. My last amp was quiet until I got it on stage and the amps noise floor became the issue so running it in the loop was a must.
Just recently joined a new band and will have my first gig in May. At this point I think I will get one and run it up front. If I find the amp is too noisy I will run it through the STEP and add a boost with it.
audiomidijace
PostPosted: Sat Apr 11, 2015 11:06 am    Post subject: Reply with quote
I'm using the rack Decimator and I have a TC Nova System in the loop with it.
The Decimator is AMAZING! It's the best device of it's kind I've ever used. I picked up the Nova System used for like $250. It provides a boost PLUS delay, reverb, modulation, pitch shifting, compression and a tuner! The TC runs at line level along with the Decimator. You can get rid of the Step at that point. The TC sounds great and has tap tempo features for your delay, tremolo, etc.
Transactions:Lots!
Post new topic   Reply to topic    MTS Forum Forum Index -> Rigs & Tones All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
