Played my new RM100 and not digging it. Any suggestions?
Goto page 1, 2  Next
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
Equalizing_Distortion
PostPosted: Sat Jul 09, 2016 2:07 pm    Post subject: Played my new RM100 and not digging it. Any suggestions? Reply with quote
Hi,
I just got my RM100 Head and connected it next to my Mesa Boogie F-100 in a 2x12 stereo cab. Mesa on one side and Randall on the the other to do some AB tests. On day one I am not feeling the Randall ,every module feels "sticky"
I have a blackface, Plexi, XTC, and Ultra Module. With an SG standard.
Blackface- I found pushing the output and then using the gain to dial in my volume yielded best results. Singe note surf guitar riffs sounded really nice. Playing some ska I found that the tail end of my notes didn't have the sparkle and sustain that I am used to.
Mesa Boogie-Single note surf sounded a little weak in comparison, however full chords had a natural decay and sounded more natural.
Overall I could be perfectly happy with the Blackface and it did sound much better than expected.
Plexi, I had this totally cranked on the gain just to get in the ballpark of what I like from an actual marshall. I thought it sounded a little thin, and again the tail end of my rhythm playing sounded a little dead. I played a Guitar wolf song (Jet Generation), Ramones, and Fifteen (Petroleum Distillation) AC/DC riffs sounded all right.
Cranking up the clean channel on the Mesa Boogie F-100 had more give when palm muting and a nice round decay, again my notes had a more natural decay.
XTC, I am not a fan of actual bogner amps but I was surprised that I actually liked this module. Only played a few minutes since it was the last one I tried and I didn't want to wake up the neighbors.
Ultra, I was seriously disappointed with this. I expected to be my primary tone, and it sound like a thin chainsaw. I will take it to band practice and i'm sure it will cut through the mix but at what cost? I was expecting more thick liquid sound. palm muting sounded good for metal but didn't have the touch response that I get from my mesa. Oh and it was super noisy, will need a noise gate.
Mesa Boogie F-100, channel 2 contour on, Gain at 100%. This is a beast of a tone, super thick, compressed, sustain for days, and forgiving when I flub a note. The only reason I wanted the randall is because at these settings the Mesa is not very reliable, the volume maxes out at about 50% and then the amp blows through tubes or powers down. I have owned 2 F-100's and 1 F-50 and they all had the same technical issues. Mesa Boogie claim I play out of spec. I was hoping to find something with more gain on tap so I don't have to push the whole amp so hard.
Should I consider getting a modded module? I was looking at some jaded faith, but I am not really sure which one. I like the idea of the 6550 but if nothing can get the roar, sustain, and attack of the mesa than this might not be the amp for me and I am thinking of returning it for a 5150 III.
CrunchBunch
PostPosted: Sat Jul 09, 2016 8:46 pm    Post subject: Reply with quote
It's interesting you found the ultra too thin. My stock ultra was much too loose on the bottom end. Not a huge bottom end, but muddy nevertheless.
Are you playing at insanely loud volumes? The combination of driving the power section / speakers hard plus the way your ears react to high sound pressures can make some modules thin out. For me there are definitely sweet spot combinations of gain and volume. Have you got the ultra on max gain? Try backing it off a bit and crank the master more.
withmittens
PostPosted: Sat Jul 09, 2016 9:46 pm    Post subject: Reply with quote
you have to put the volume of the mods past noon and more toward 2pm minimum and adjust your gain from there other wise it sounds thin. these amps need to push air. Try a drive pedal if that's too loud but try to open the module volume as much as you can
try swapping power tubes or pre tubes.
Modded modules are far above the stock. I know it sucks to think you've got money in already and need to send off your modules but it is worth it.
RM50, RM4+RT2/50
CrazyNuts' Dirty Sanchez, Salvation: C-Watt, DuoPlex, Selma, Supra, custom Twinface
Various cabs
SG, LP Std., Strat
Corium_AZ
PostPosted: Sun Jul 10, 2016 3:20 am    Post subject: Reply with quote
Agree with the above. I run my rm100 with each module volume around 4-5 o'clock, with gain to suit. I also use a drive pedal extensively (a TC Nova Drive, since it's midi programmable like the RM). Also, I'd suggest installing a foglifter or mda board. I hated my RM when I first got it as it sounded like a blanket was over the speakers. Foglifter solved that problem. They're like $40-$50, and easily installable.
Oh, and jumper your parallel loop and run the loop level about 1-2 o'clock. Really wakes up the RM.
Btw, I run the power section master at only about 9 o'clock. With all the module volumes pretty much maxed, it's insanely loud there already...
Band Sites (Until The Sun)
http://www.reverbnation.com/untilthesun
https://www.facebook.com/UntilTheSunBand
Budda Superdrive 45, Orange Rocker 30, Zinky 4x12, '72 Deluxe Tele and MIJ Greco LP Custom
SpitfireMusic
PostPosted: Sun Jul 10, 2016 4:23 am    Post subject: Reply with quote
1. I'll agree with the others about setting the module levels "properly" I think Rob from jaded faith actually stickied a cool post on here about it somewhere.
2. I'd probably experiment with power tubes to better suit your tonal/feel preferences
3. In the amp itself trying a 5751 in the phase inverter spot instead of a 12ax7 and a couple of good quality 12ax7 in the other two slots (v2 isn't as critical unless you try the effect loop trick mentioned above)
4. A foglifter/mda board can make a pretty noticeable difference as well
5. Consider getting your modules "upgraded" I know that base mods from Rob can make a huge difference and aren't quite as expensive as the full on mods. Plus with a base mod he can pretty much give you whatever your heart desires of course within the confines of the MTS platform but Rob at jaded faith has shown us that a lot can be done.
6. New module tubes just be sure that the tube on the right is a Chinese or JJ tube as this position is a cathode follower and a lot of current production tubes like those from New Sensor tend to be prone to failure in that position
Some other food for thought is while the cab/speakers you have may work great with your Mesa every amp is different sometimes certain things work better with certain amps/modules than others. I find that speaker/cabinet selection can be one of the crucial aspects to attaining a particular sound/feel from any amp not just in MTS.
In any event as discouraging as some of this might seem don't give up just yet on MTS while it has its drawbacks it also has some major advantages and can really be dialed in to a multitude of different tones and settings.
PostPosted: Mon Jul 11, 2016 12:14 am    Post subject: Thank you, Reply with quote
Its getting a little late but I wanted to thank you guys for responding.
I am going to give this amp another go at practice, I had been lusting for the modular for a long time.
To answer a few of the questions,
1)Yes, I figured out really quick that volume on the modules must be at least 3-4 O'clock. Which to me makes sense for how the amp is designed.
2) I probably will never use a boost pedal. Although I aim to write really heavy riffs and I know alot of metal guys swear by boost pedals I am pretty much just playing punk venues/houses and anything on the floor will get soaked in beer and stomped on so I choose to avoid the whole pedal thing.
3)I had considered a fog lifter right away, and yes stock there seems to be something off about the interplay between depth and presence.
4) and last I have 6L6 power tube which I have always preferred to EL84, so I don't think its a power section. I actually picked this head because it already had a full set of new 6L6'S
Tbone81
PostPosted: Sat Nov 19, 2016 12:15 pm    Post subject: Reply with quote
I know this post is a little old but how did it work out? I was having a similar problem with an RM50 head, turns out my power tubes just werent biased properly. The plate voltage was a little too low. Once its was in spec it was like "wow, ok...thats were all the low end comes from."
op1e
PostPosted: Thu Nov 24, 2016 10:00 am    Post subject: Reply with quote
I dunno how you guys run your channel volumes past noon. I do that and they just go full R.... and feedback. And thats with my master on like 2. Definitely need to do at least base mods or get the C3 cap done in those. The only one I can deal with stock is the SL+.
Capt_Tippy
PostPosted: Thu Nov 24, 2016 10:13 am    Post subject: Reply with quote
Turn down your gain knob
Moral of the story, buy extra tubes, and don't pay up charges. Good luck, cause tube buying is a crap shoot.
You're correct. I probably have no idea what I'm talking about. I'm not even sure why I bothered to say anything in the 1st place.
Corium_AZ
PostPosted: Thu Nov 24, 2016 2:25 pm    Post subject: Reply with quote
Only two possibilities here. 1) as was said, your running your gain WAY too high, or 2) there is something wrong with your amp or tubes.
I always run all of the module volumes at near max, gain anywhere from 9 o'clock to 2 o'clock, and master to suit for volume (can get anything from bedroom level to ripping the paint off the walls). Sounds fantastic this way at all volumes.
op1e
PostPosted: Fri Nov 25, 2016 10:53 am    Post subject: Reply with quote
I run my gain just below noon and boost with a Maxon 808. If I gotta turn the gain down that low its probably gonna be way too weak but I'll try it.
Capt_Tippy
PostPosted: Fri Nov 25, 2016 1:49 pm    Post subject: Reply with quote
Depending on the module I have some of my gain's set at 9 op1e. I have 1 module that I need to turn the gain all the way to the max, but most of the "high gain" modules are set closer to 9-10. I put a compressor in the front to boost it a little, and I also use a BBE to boost it on the backside.
You'll find that if you turn the gain down to where the feedback goes away it usually doesn't change the tone as much as you would expect.
Also get a good noise gate that way you can turn the gain up just a little more. I have one for sale if you're interested.
op1e
PostPosted: Fri Nov 25, 2016 2:53 pm    Post subject: Reply with quote
I'm running anywhere up to 3 gates lol. I have an NS-2 in the loop switcher, the GSP 1101 and G Major on the loop side if I need it. So then the modules saturate more with the gain lower and the level up I presume? You mean 9 o'clock I'm guessing. Got practice in a couple hours, can't wait to try. Gonna also set my patch levels on the GSP 1101 all the way down to 30 or 40. With the crap loop in the RM my amp models in the 1101 can't even come close to the same level with them on 100 and the real amp on 60. Plus that will help me "Power Break" the amp a bit. I just might have to go to jj 6v6 to open up the power section in this thing. It's 20x louder than my Peavey Ultra 120.
Capt_Tippy
PostPosted: Fri Nov 25, 2016 3:05 pm    Post subject: Reply with quote
Well... my opinion is that where I see this conversation going ends with me redesigning your entire rig for you LoL. So.... since I don't have time for that.. Wink
I have an 1101. I use it for speaker emulation (with the hacked firmware) so I can do direct recording out of my rig, but I wouldn't have it in my effects loop. If it didn't do the speaker emulation I'd probably give it away to some kid LoL
Anyways, yes I meant 9 oclock. The noise gate I have is an ISP Decimator ProRack G. Much better gate than any of the ones you mentioned. Let me know if you're interested.
audiomidijace
PostPosted: Fri Nov 25, 2016 3:59 pm    Post subject: Reply with quote
You might try running the send from your Mesa in to the return on the RM100. This would at least exclude the preamp section of the RM from being the issue. You'll be able to evaluate just the power section. Do make sure the the tubes are biased properly.
RM50, Orange PPC412 w Celestion V30s.
Modules: SG-MK22, JF Twox .
Pickups:MotorCity & BareKnuckle
Dunlop 95Q Wah, TC Nova System, Wampler Tumnus
AVID ELEVEN RACK & Atomic Amplifier 12
Transactions:Lots!
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
