Dirty Sanchez MTS mod based on Dirty Shirley
Goto page Previous  1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules
Capt_Tippy
PostPosted: Sat Oct 15, 2016 7:04 am    Post subject: Reply with quote
Id recommend you go with the digital solder station
I have something similar to that.
https://www.amazon.com/Pro-Line-70w-Soldering-Station/dp/B00IT305RS/ref=sr_1_19?s=hi&ie=UTF8&qid=1476536930&sr=1-19&keywords=radioshack+soldering
It works very well.
You do need things like tiny needle nose pliers and etc. and that 3rd kit does seem like it has some nice picks and etc in it, but the solder iron is not nearly as nice. I'd get the tools separately. You won't even use most of the tools in that kit.
Something like this is really helpful too
https://www.amazon.com/RadioShack%C2%AE-Helping-Hands-with-Magnifier/dp/B007Z7PXDK/ref=sr_1_17?s=hi&ie=UTF8&qid=1476536930&sr=1-17&keywords=radioshack+soldering
Moral of the story, buy extra tubes, and don't pay up charges. Good luck, cause tube buying is a crap shoot.
You're correct. I probably have no idea what I'm talking about. I'm not even sure why I bothered to say anything in the 1st place.
CrazyNutz
PostPosted: Sat Oct 15, 2016 3:09 pm    Post subject: Reply with quote
A solder station is a good thing to have. You also need a desoldering solder sucker. That third kit has one (the long blue tube looking thing)
Whatever you go with, make sure you get extra tips, and that the tips are easy to come by when you need to order more.
withmittens wrote:
My soldering tools are a piece of crap. I need something that won;t destroy this board. I"m looking at a few things....
http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC/ref=sr_1_7?s=hi&ie=UTF8&qid=1476489910&sr=1-7&keywords=soldering+iron
http://www.amazon.com/X-Tronic-3020-XTS-Digital-Display-Soldering/dp/B01DGZFSNE/ref=sr_1_14?s=hi&ie=UTF8&qid=1476489910&sr=1-14&keywords=soldering+iron
http://www.amazon.com/dp/B01E1ISGH0?psc=1
the first two seem standard, the third may just be a bunch of extra junk....
any thoughts?
withmittens
PostPosted: Sat Oct 15, 2016 4:03 pm    Post subject: Reply with quote
I ordered a solder pump.
F'd up a trace on C9 when I decided to go ahead and move forward. Bastard silver ring came up off the board. Probably the sloppiest thing I've done. I tried to fix it by adding solder and make a solid bridge to the trace but it's still loose.
I guess I might as well move forward when I get the pump but if anything that trace will F me in the end. Looking into how to repair it. I have about 8 more components left to do
If I can get it then back solid good, if not it was a good try at something new. a bit tougher than building a pedal kit.
RM50, RM4+RT2/50
CrazyNuts' Dirty Sanchez, Salvation: C-Watt, DuoPlex, Selma, Supra, custom Twinface
Various cabs
SG, LP Std., Strat
Capt_Tippy
PostPosted: Sun Oct 16, 2016 6:51 am    Post subject: Reply with quote
Just use a wire to jump the trace
PostPosted: Sun Oct 16, 2016 8:08 am    Post subject: Reply with quote
What he said!!!
My first few self modded modules had wires all over from screwing up the traces....Run it underneath to avoid making a mess on top....
withmittens
PostPosted: Sun Oct 16, 2016 11:42 am    Post subject: Reply with quote
this means to run a wire from the leg at the bad trace ring to the next point on the trace route? In this case it would go from c9 to R25?
RM50, RM4+RT2/50
Various cabs
SG, LP Std., Strat
Capt_Tippy
PostPosted: Sun Oct 16, 2016 4:32 pm    Post subject: Reply with quote
yes that's what it means withmittens
withmittens
PostPosted: Sun Oct 23, 2016 1:14 pm    Post subject: Reply with quote
anyone else try this mod but me?....and CrazyNutz, of course?
RM50, RM4+RT2/50
Various cabs
SG, LP Std., Strat
bbaug14
PostPosted: Wed Oct 26, 2016 11:24 am    Post subject: Reply with quote
I'm considering trying this mod out. I'd love to hear a clip of it from one of the guys that did it. I have an Egnater SL2 that is a bit much gain for me. I think the DS mod would be more my style, but I'm curious if it's a little loose and muddy in the low end based on the values I see.
CrazyNutz
PostPosted: Thu Oct 27, 2016 1:15 pm    Post subject: Reply with quote
I have not tried the SL2. The DS is however less muddy, and tighter than a SL+, gain is about the same. If you want less gain you can lower the value of r7. If you want even tighter you can change c8/c9 to 0.0022
CrazyNutz
PostPosted: Thu Oct 27, 2016 9:03 pm    Post subject: Reply with quote
Here's a crappy phone recording:
https://soundcloud.com/user-864489142/dstest
JKD
PostPosted: Sun Oct 30, 2016 3:24 pm    Post subject: Reply with quote
Gives good impression of what it sounds like in room....missing quote a lot of low end....due to (phone) recording method?
Great choice of song to! \m/
Synergy - BE,HBE,DS,SLO,VH4,TDLX,Metro
JF-Dual MachX+Voxless+ERect+MarkX
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Randall - Brahma,Scary, Grail, SuperV
CrazyNutz
PostPosted: Mon Oct 31, 2016 7:21 am    Post subject: Reply with quote
Yes, and no. I had the bass knob at 1/3, mids at 1/2, and Treb. Dimed
It has plenty bass on tap, I just had it rolled back to keep my phone mic from farting out.
withmittens
PostPosted: Fri Nov 04, 2016 1:24 pm    Post subject: Reply with quote
With the help of CrazyNuts I've completed the DS mod. Don't know how to read a schematic so he was able to find where I went wrong and made corrections. Thanks CrazyNuts
This mod sounds great. It's structure is planted firmly in the Marshall camp put with more gain than a plexi, more open and toppy than a vintage Marshall yet still has a full bottom end. I'm going to add a switch for High/Low input and a mid shift. possibly a tightness switch as well, which it needs at higher gain settings.
I'm going to make some quick clips this weekend before the additional mods.
This is just my first impression and I'll try to compare it to the clips on YouTube for what that's worth. I really like my Duoplex for lower gain Marshall tones but this DS goes higher in the gain, maybe toward an 800 but possibly more gain than that. it's very touch sensitive and cleaner settings are very punchy and lush, although as a whole the mod is on the brighter side of all this but in a very good way. Still has good chug and thump on the bottom. Very Vintage, which is my flavor
Thanks again CrazyNuts. It's worth doing this mod for sure
EDIT:
I made some clips but they sound like s*&t because of my mic setup. I'll try again soon
RM50, RM4+RT2/50
Various cabs
SG, LP Std., Strat
CrazyNutz
PostPosted: Fri Nov 04, 2016 1:36 pm    Post subject: Reply with quote
No problem, my pleasure.
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules All times are GMT - 6 Hours
Page 3 of 5
