What Type of Speaker Do You Use with your Modular System?
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
Speaker type with your MTS?
Greenback
8%
 8%  [ 1 ]
Vintage 30
91%
 91%  [ 11 ]
Total Votes : 12
JMMP
PostPosted: Sun Jan 08, 2017 2:46 pm    Post subject: What Type of Speaker Do You Use with your Modular System? Reply with quote
What type of speaker do you use with your MTS setup? Do you alter speaker choice when you swap out modules? Was it ever revealed how modules were developed, IE were all modules developed using the same speaker, or were each developed using the type of speaker typically associated with that type amp (marshall/greenback, recto/v30, top boost/blue)? Thanks for your responses!
Good Deals with: lintycreep, msm222, gtrlw
bryantabuteau
PostPosted: Sun Jan 08, 2017 3:42 pm    Post subject: Reply with quote
While I use V30s in the cab connected to my MTS setup, I've been using a 2-Notes Torpedo Live load/cab sim rack unit to do most of my monitoring recently (into a couple of JBL monitors). With that, I switch cab/speaker types via midi based on the preamps I'm using. I find it's much nicer to use V30 emus for my recto mods, greenback emus for my marshall mods etc.
Live, the V30 tends to work fine for all of them though.
RM100 - Clean, SL+, Recto, Blackface, Salvation JJ Dirt, JF Mark X, Salvation Legend, Salvation Dreadplate
JKD
PostPosted: Sun Jan 08, 2017 4:03 pm    Post subject: Reply with quote
Mostly v30 but not just that:
1. Main 4x12 has v30/G12h30 in x-pattern
2. My 2x12 has v30/G12M65 Creamback
Synergy - BE,HBE,DS,SLO,VH4,TDLX,Metro,Plexi
JF-Dual MachX+ERect+MarkX
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Randall - Brahma,Scary, Grail, GTO, SuperV
VitaminG
PostPosted: Tue Jan 10, 2017 7:48 pm    Post subject: Reply with quote
whatever came stock in the Genz Benz G-Flex 2x12
Spencer4hire
PostPosted: Tue Jan 10, 2017 9:07 pm    Post subject: Reply with quote
I think those were eminence legends.
VitaminG
PostPosted: Tue Jan 10, 2017 10:14 pm    Post subject: Reply with quote
that makes sense. The G-Flex replaced a 4x12 with Eminences in it and both cabs sounded quite similar. That's a big part of its appeal - it's a big sounding 2x12, takes up a lot less room in my car Wink
Spencer4hire
PostPosted: Wed Jan 11, 2017 1:41 am    Post subject: Reply with quote
I used to have one and I thought it sounded pretty darn good and like you said it was easy to move around with nice handles they have.
withmittens
PostPosted: Wed Jan 11, 2017 9:23 am    Post subject: Reply with quote
cab 1 semi open back - Celestion G12H 70th Anniversary + Vintage 30
cab 2 sealed back - Creamback 60 + Reeves cast Purple
cab 3 open back- Eminence Maverick attenuated speaker
they all sound great. cab 2 works great with the 50R, C-Watt and is clear, crisp although not harsh or spikey
Cab 1 is great for Selma, Twinface, Duo
Cab 3 is for all of them at a slighly less output. each one is very balanced and does not have a huge mid hump or fizz like a v30 alone has. it was my goal to eliminate this yet still get the classic Celestion sound.
The Reeves is so good as is the Creamback. If I were to use a Creamback alone it would be the 75 rather than the 60
RM50, RM4+RT2/50
CrazyNuts' Dirty Sanchez, Salvation: C-Watt, DuoPlex, Selma, Supra, custom Twinface
Various cabs
SG, LP Std., Strat
trimix
PostPosted: Wed Jan 11, 2017 6:07 pm    Post subject: Reply with quote
1st choice is a pair of Randall 4x12s, both with Vintage 30s and G12T-75s in an x-pattern.
If using just a 1x12 combo, I use a WGS ET-65 but prefer it combined with a WGS Veteran 30 in a second extension 1x12.
Find the WGS versions work better in singles and pairs but the Celestions cancel perfectly in quads.
Randall- RM4, Clean, 1086, Mr Scary, Grail
Egnater- SL2X D/S
Salvation- TwinFace, MarkUs
Jaded Faith- Twox, XTC, Custom RVerb
Sacred Groove- Custom SL+
Mesa/Boogie- Stereo Simul-Class 395
(2) Randall 4x12- X-pattern Vintage 30/G12T-75
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
