Has MTS ever let you down?
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
JMMP
PostPosted: Wed Feb 08, 2017 5:51 pm    Post subject: Has MTS ever let you down? Reply with quote
As the title says, has MTS ever let you down? I don't mean tonally so much as durability/ reliability. I am wondering if these amps and modules are built to hold up for many years to come, especially compared to other amps/ preamps available.
Thanks for any responses!
Good Deals with: lintycreep, msm222, gtrlw
PostPosted: Wed Feb 08, 2017 6:59 pm    Post subject: Reply with quote
I have had some modules in heavy use for 5+ years....The amps I have had problems with, the mods, none...A tube will go out or a pot gets scratchy, that's normal....Totally die? Never...
The amps have had some known issues with arching and other random issues here but nothing that can't be fixed up....I feel confident taking an RM50 to a gig still....I bring a backup but that's just common sense...
Corium_AZ
PostPosted: Wed Feb 08, 2017 10:44 pm    Post subject: Reply with quote
I've been playing and gigging my RM100 for a good 5 years now - regular heavy use. Never had one problem I didnt cause myself. And, I never bring a backup. One of the most reliable pieces of gear I own!
Band Sites (Until The Sun)
http://www.reverbnation.com/untilthesun
https://www.facebook.com/UntilTheSunBand
Budda Superdrive 45, Orange Rocker 30, Zinky 4x12, '72 Deluxe Tele and MIJ Greco LP Custom
ned
Site Admin
PostPosted: Thu Feb 09, 2017 8:28 am    Post subject: Reply with quote
I gigged with my Mod50 combo for 2 years before going the digital route. Never a problem. Only thing I ever did was change tubes.
Grail Tone - Amp Settings
My Rig: Egnater Mod 50 1x12 Combo w/ VX and SL2 modules
FX: Digitech GSP1101, RM4 w/ SuperV, JTM45, Plexi, XTC, KH2, TB
Personal Web Page
PostPosted: Thu Feb 09, 2017 9:01 am    Post subject: Reply with quote
What do you play live now ned?
JKD
PostPosted: Thu Feb 09, 2017 9:55 am    Post subject: Reply with quote
Had an early RM100 that, while it never failed, needed the wire wrap mod to prevent arcing....it was rock solid.
I also sent an RM100 to Egnater for dual module conversion....he did the wire wrap and fixed the presence/density plus couple of later production updates whilst doing the mod. It never failed though....often wonder where that amp is now.
Also had an RM50 that completely blew a hole in the circuit board/burnt out due to same issue. This was back in the days Randall had support though...sent me a new mainboard with wire wrap fix and i self installed - it's been trouble free ever since.
TLDR; I've had over 10 of these suckers and only one actually failed.
Synergy - BE,HBE,DS,SLO,VH4,TDLX,Metro
JF-Dual MachX+Voxless+ERect+MarkX
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Randall - Brahma,Scary, Grail, SuperV
Bradle
PostPosted: Thu Feb 09, 2017 3:01 pm    Post subject: Reply with quote
I've been hammering my RM100 head for not quite 2 years now and I think I've blown 1 fuse due to a bad tube. I'm very trusting of this amp. I also have an RM50 that's never failed me, but I've never used it as a workhorse. Out of curiosity does anyone know when Randall fixed the arcing issues?
werdna
PostPosted: Thu Nov 02, 2017 8:43 am    Post subject: Reply with quote
I have an RT2 RM4. The RT2 used to cut out after half and hour. Then I figured on separating them in the rack so that air acted as insulation and the problem went away. The only complaint I have is that the rig is physically big and weighs a ton, which makes it tough to fit into a tight gig.
JKD
PostPosted: Thu Nov 02, 2017 10:32 am    Post subject: Reply with quote
Adding to this, had a single channel M4 that had intermittent noise/signal problem.
I traced it back to the input connections, there's one on front and one on back but they all go through one cable to feed the signal to the module backplane (from memory)
I think one section of the cable failed due to heat, worked fine after placing it.
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
