Rm100 midi help with boss es5
Kainer
Hey guys, had my amp for a while now,
I'm running a boss es5 midi looper and wanted to to know, the 7 pin connector still required to run the midi?
On another note my normal midi cable doesn't want to plug into the es5 at all which is annoying
I'm pretty sure if the midi pedal you're using has its own power supply then you only need a 5 pin cable. I read on here somewhere that the extra 2 pins just supply power to the original Randall pedals.
