Where is the mains fuse on an RM20?
yourguitarhero
Edinburgh
My RM20 won't turn on.
I am trying to check the mains fuse, but I can't find it.
There are markings for it next to the IEC connector on the back.
However there doesn't seem to be a drawer or anything. I had a look at the back of that bit and it seems like it could be inside a wee black tube but it doesn't seem removable?
Am I being really stupid?
Hey - the mains fuse is under the square thing with the voltages on it:
There should be a little lip on one side and you can pop a screw driver under there and pop it off (make sure you take a note of what voltage it was set for first - take a picure on your phone is normally best) and simply replace the fuse and put it back in - job done!
Yeah, the fuse was all smashed in there.
Do these use the bigger sized fuses? As I had one the right kind but the normal size you get for HT fuses. But it just wobbled about and the amp still wouldn't turn on.
And I tried the (working, small sized) fuse in its holder from my RM50 but again, no power to the amp although the holder fit correctly though maybe isn't reaching all the way back. Worked again back in the RM50.
