MIDI part 2
Rigs, Clips & Tones OH MY
wesman11483
MIDI part 2
Post by wesman11483 » Sun Jul 16, 2017 7:07 pm
Hey all...got dune GREAT advice last time for incorporating MIDI into my rig. As most of us are so prone to do, I'm tweaking it...but actually paring it down...
I have an 8 button MIDI switch (3 banks of 8)...I want to use it to run my RM4 and my H9. Here's the rub: H9 is 5 pin. I have an adapter cable with phantom power for the footswitch already...so qoukd it be best to
A) go MIDI in to RM4, then thru to H9 using the 7 to 5 cable (minus the power) or
B) go MIDI in to H9 and then thru to RM4 with a 5 pin cable? What would I be losing?
Thanks in advance!
Randall RM22: Jaded Faith Voxless, Salvation Dreadplate
Deals with Firebird V, blacksun, Ty, and others...
webrthomson
Post by webrthomson » Mon Jul 17, 2017 5:07 am
The only difference between a 5 and a 7 pin midi cable is the power - if you dont need the power then use a 5 pin cable.
MarcoR
Post by MarcoR » Mon Jul 17, 2017 5:52 pm
If you're phantom powering the controller with the RM4, then go with option A.
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
wesman11483
Thanks
Post by wesman11483 » Sat Jul 22, 2017 1:30 pm
Thanks guys.
Got it all wired up, but being MIDI slow is coming up again...seems a reprogram us needed.
Anybody have experience using the RM4 and H9 together with one controller?
