Best preamp tube for increased headroom?
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules
Ricey
PostPosted: Mon Aug 14, 2017 9:22 pm    Post subject: Best preamp tube for increased headroom? Reply with quote
What would be the best replacement preamp tube(s); e.g., 12AY7, to increase headroom in a stock Randall Tweed Module. I can get a great sparkly clean tone with the gain below 10 o'clock, but it starts breaking up quite a bit after that with humbuckers. I am using that module in channel 1 in my RM100 combo as my primary clean channel, so I would really like some additional headroom. Can tubes be mixed and matched in the modules; e.g., mix a 12AY7 with a 12AX7 or do they both need to be the same? GC has lower gain 12AT7s, not 12AY7s, but I notice 12AT7s seem to be mostly be used as phase inverter tubes, so I did not buy one.
RM100/RM50 Combos; KH-1, Blkfc,Twd, Plx, Brwn, 1086, SL+, Recto and Ult XL; Jackson Fusion; LP, AmDlx Strat; CP Jag HH, Cobain Stang; Boss, MXR, Dunlop, DOD, Dgtec, Sldgld, Barber, Way Huge, Pigtronix, Maxon, TC, ProCo, Menatone, Earthquaker, and Tech21.
Spencer4hire
PostPosted: Mon Aug 14, 2017 10:56 pm    Post subject: Reply with quote
Try a 5751 there.
tschrama
PostPosted: Tue Aug 15, 2017 4:03 am    Post subject: Reply with quote
Why dont you turn down the gain below 10 oclock?
my small atelier called 's-Gravenmade | Follow me www.sgravenmade.com | Join my Amp Building Workshop 14 april 2018
Good deals with: C2ply, BenMesaBoog, YouguitarHero, nitrous12, kylendm.
View user's profile Send private message Send e-mail AIM Address
PostPosted: Tue Aug 15, 2017 6:11 am    Post subject: Reply with quote
5751 for sure
warmachine67
PostPosted: Tue Aug 15, 2017 7:03 am    Post subject: Reply with quote
You can mix types in a module without any problems. I have had luck even using a 12at7 in either one or both positions of Fender type modules. I've mixed 12at7's with au7's and ax7's in any arrangement and it changes the headroom to varying degrees.
But, 5751 is great too and sort of between a 12ax7 and a 12au7. You usually have to go somewhere online to find them since GC probably won't stock then.
Whatever you choose, I recommend using a JJ brand in the right hand tube (looking at the face plate / knobs) position.
Ricey
PostPosted: Tue Aug 15, 2017 9:40 pm    Post subject: Reply with quote
So is the tube on the right side V1?
warmachine67
PostPosted: Wed Aug 16, 2017 2:44 am    Post subject: Reply with quote
I believe it to be v2, and the one on the left (looking at the faceplate) is v1
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules All times are GMT - 6 Hours
