replacement dual channel mini pots
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules
eero
PostPosted: Sun Sep 17, 2017 8:51 am    Post subject: replacement dual channel mini pots Reply with quote
Hi all,
I need to replace some mini pots (gain, volume) on my Egnater dual modules;
it seems like they are Alpha 1 Mohm Logarithmic 13mm diameter body, i already checked Mouser and Digikeys but haven't found nothing, only standard 16mm pots for single modules.
Some of you guys know where I can find them, if possible, in Europe?
Also, there seems to be two different printed codes at the back (one is 7N4, the other is 6E1), though the value is the same for both?
Thanks in advance for your help,
cheers
JKD
PostPosted: Sun Sep 17, 2017 12:56 pm    Post subject: Re: replacement dual channel mini pots Reply with quote
eero wrote:
Hi all,
cheers
Might be worth sending an email to Bruce.
Synergy - BE,HBE,DS,SLO,VH4,TDLX,Metro,Plexi
JF-Dual MachX+ERect+MarkX
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Randall - Brahma,Scary, Grail, GTO, SuperV
eero
PostPosted: Sun Sep 17, 2017 1:17 pm    Post subject: Reply with quote
obviously this would be the best solution, but I know he is very busy ... so I thought maybe somebody here had the same problem and could give me an answer.Wink
thank you anyway for your answer
galao
PostPosted: Sun Apr 08, 2018 1:04 am    Post subject: Reply with quote
Alpha 12mm PC mount pots should fit:
http://www.mouser.com/catalog/645/usd/822.pdf
They are hard to find. Banzaimusic has some values in stock:
https://www.banzaimusic.com/Alpha-12mm-D-Shaft-Pins/
DUAL CHANNEL MODS
https://yuneo.de
eero
PostPosted: Sun Apr 08, 2018 8:23 am    Post subject: Reply with quote
Hi Paul,
yes I had already seen Banzai, the type is not exactly correct even if perhaps it could be adapted, but unfortunately there is not the value that would serve me (1 M);
it seems they are no longer on the market.
I tried to contact Bruce directly, but for some reason my mails did not reach him ...
contacted through the email of his site (not the personal one) some of his collaborators forwarded my request, he replied very kindly offering to send me the pots, but my answers still do not arrive, as soon as I have time I will try to contact him again .
Anyway thanks for the kind thought
Smile
galao
PostPosted: Sun Apr 08, 2018 9:03 am    Post subject: Reply with quote
Hi Egidio,
it really seems as if these pots were discontinued, as you can hardly find them anymore. Thatīs not good cause all pots need to be replaced on the long run.
DUAL CHANNEL MODS
https://yuneo.de
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules All times are GMT - 6 Hours
