Syn 1 Mesa Boogie Mark V FX Loop
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules
Scott Isaksen
PostPosted: Mon Nov 13, 2017 7:37 pm    Post subject: Syn 1 Mesa Boogie Mark V FX Loop Reply with quote
Tried running the syn 1 through my Mark V but only bypass worked . Then I went through a Blackstar HT5 and it worked perfectly. Any thoughts. I'm selling the Mark V anyways but just in case someone else has one maybe you can say why it doesn't work Thanks and it sounds GREAT>
Face Your Fears and Live Your Dreams
SRI
webrthomson
PostPosted: Tue Nov 14, 2017 4:58 am    Post subject: Reply with quote
The loop needs to be series loop not parallel, don't know about the Mark V, but the loops on the Rectos don't work either?
jimw427
PostPosted: Fri Jan 05, 2018 2:08 pm    Post subject: Reply with quote
I've talked with the Steve at Synergy about my Boogie F-50 and its mentioned in their manuals that there are some issues or concerns with the loops in the boogies as they continue to run a dry signal through the loop since they are parallel loops and thats what causes the issues with the Boogie loops.
Jim
webrthomson
PostPosted: Sat Jan 06, 2018 8:53 am    Post subject: Re: Syn 1 Mesa Boogie Mark V FX Loop Reply with quote
Make sure the rotary on the back is set to "On all"?
Check you are running a the right level, either +4 / -10DB depending on the loop - should tell you in the boogie manual which the loop is.
If the rotary control is set correctly it might well be the semi parallel nature of the boogie standard effect loop - thought I would have expected you to get sound, just not very good sound Smile
Jaded Faith
PostPosted: Wed Jan 10, 2018 8:37 am    Post subject: Reply with quote
Make sure the MKV loop is active and not bypassed or set to Footswitch. Boogie loops are often a headache to my customers, but the MKV loop is in series unlike a lot of their other amps.
www.jadedfaithmods.com
https://www.facebook.com/JadedFaithMods
Email: info@jadedfaithmods.com
Authorized Service Center for US Music and Egnater
Authorized Reseller for Celestion, Scumback & Mercury Magnetics
View user's profile Send private message Send e-mail Visit poster's website
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules All times are GMT - 6 Hours
