SYN2 into powered FRFR speaker
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules
serge20261
PostPosted: Sun Nov 19, 2017 2:39 am    Post subject: SYN2 into powered FRFR speaker Reply with quote
Can I go straight into a powered Wedge?
Confused if I need anything else,like a IR to make this happen,and if so how
I’m a noob so would need step by step instructions
All the gear and no idea
PostPosted: Sun Nov 19, 2017 6:04 am    Post subject: Reply with quote
INHO, FRFR tech is kinda sketchy still and designed more for digital modelers. FRFR is designed to work with an IR so you would need to interface your SYN2 with a computer or hardware that can use IRs...
If you went straight in, it would be a fizzy sounding disaster...
Good luck!
withmittens
PostPosted: Sun Nov 19, 2017 8:18 am    Post subject: Reply with quote
couldn't one of those torpedo gadgets do this? not that it makes sense but, technically....
RM22, RM4
CrazyNuts' Dirty Sanchez, DuoPlex, Selma, Supra, Twinface, Evil Kitty, CC30, XTC
SG, LP Std., Strat
MarcoR
PostPosted: Sun Nov 19, 2017 8:31 am    Post subject: Reply with quote
Yup, the CAB would be ideal but the built in speaker emulation is great as well.
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
k9blek
PostPosted: Tue Nov 21, 2017 7:47 am    Post subject: Reply with quote
Good luck!
I thought the synergy mods had cabinet simulation ?
RM22/100BP-JF Legato/PlexiTweed/Silverado - Good deals: schlagdog, khingpynn, Nitrous, alowerdeep,rlord1974,BIGKAHUNA,ColdMachine, c2ply,RisingFarce,MattFigOldTimer,JimW427,and Kevrock25, L82theParty,Nitrous,
djdayson
PostPosted: Tue Nov 21, 2017 8:24 pm    Post subject: Reply with quote
Ther are any number of IR loaders and tube power amp sims that work wonderfully with MTS/Synergy, assuming one knows how to pick a IR, i.e. how to mic a cab etc?
The Torpedo CAB works beautifully for this, been doing it for years, and there are now other options from Mooer, Nux, AMT, and Atomic etc.
I've only used the Two Notes Torpedo CAB/WOS so far, and I love it DI'd, or through cabs (guitar or FRFR) via lightweight solid state power.
SynergyAmps
PostPosted: Sun Nov 26, 2017 1:10 am    Post subject: Reply with quote
You can absolutely connect the SYN-1 or SYN-2 to a full range monitor like the Friedman ASM-12. It sounds fantastic.
If you want to use an IR, then you need to bypass (turn off) the cabinet simulation. There is a small push button switch on the back of either unit that indicates “CAB SYM BYPASS”.
We spent a LONG atone dialing this in.
mfgobbi
PostPosted: Sun Nov 26, 2017 9:23 am    Post subject: Reply with quote
No offense but, it's funny to see people not willing to give up tubes in their signal chain, but accept software emulation of speaker, cabinet, miking, etc, when, really, those variables affect the sound in almost every respect 10 times more than preamp tubes (as opposed to transistors), plus the fact that preamps are easier to emulate than speakers and cabs.
RM4, RT2/50, RM100, and a mod or 2.
View user's profile Send private message AIM Address
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules All times are GMT - 6 Hours
