Syn2 into return of mesa dual rec
keg8605
Has anyone succesfully run the syn straight into the fx return of a dual rec? So I know they have bad parallel loops, however for a backline in Dominican Republic are choices are dual recs or JCM 800. I'd like to not bring the synergy but our backline choices suck.
Does the JCM800 not have a loop?
I'd use that if it has a series loop, has a great power section.
Worst case..bring a Tubescreamer and EQ and use the '800 if the Synergy stuff doesn't work out.
I have lots of experience with Dual Recs and FX but not the Synergy...all the mix effects work great, anything that required 100% effected sound hand phasing issues....because there was still some dry signal mixed in with the parallel loop.
