SYN-2 Volume-Level Settings
Area for the Synergy line of amps and modules
Rising Farce
Post by Rising Farce » Sat Aug 10, 2019 2:02 pm
SYN-2 owners, how are you setting your module and rack master-volume levels relative to the power amp (or host amp) master? I'm having a bit of trouble striking the right balance of tone (from the module), fullness (from the amp), and minimal background noise.
Lespauled
Re: SYN-2 Volume-Level Settings
Post by Lespauled » Sat Aug 10, 2019 8:22 pm
I have a SYN1, and I've been running through a ton of different sounds with the Plexi module. Just today, I tried full dime on the level and volume. It sounded great, had some noise, but not much.
Rising Farce
Post by Rising Farce » Sun Aug 11, 2019 1:47 pm
Thanks for the input.
I'm not sure running both volumes wide open would work with the (extremely high-gain, and thus somewhat noise-prone) Engl, which I use quite a bit, but I'll give it a shot.
Overall, I'm trying to get an idea of what role the SYN-2 master plays in the overall equation, as it's an additional variable over the modular heads I've used in the past.
retropete
Post by retropete » Fri Aug 16, 2019 9:42 am
I've been trying to keep the red clipping light from being continuously on. That means my module and master volumes are relatively low. Otherwise I seem to get some clipping distortion as opposed to harmonic distortion. It seems to be a much different approach than on my Lynchbox. But who knows, I may be doing something wrong ;-)
No trees were harmed in the sending of this message. However an extraordinary amount of electrons were inconvenienced.
MarcoR
Post by MarcoR » Fri Aug 16, 2019 12:01 pm
What is the "red clipping light" you refer too? Do you mean the sag indication light?
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
retropete
Post by retropete » Fri Aug 16, 2019 12:14 pm
Oh is that what it is? Haha. When in doubt, read the manual ;-) Still, when I have the volumes up high, I it seems I get some clipping distortion.
gaboocho
Post by gaboocho » Tue Sep 17, 2019 6:36 pm
I set it to 11
