Posted: Tue Jul 17, 2007 8:32 am Post subject: How To Bias the RM100?
Forgive my ignorance here, but how do I go about biasing my RM100? what is the proper procedure?
I would really like to learn to do this on my own, since I'm experimenting different power tubes all the time, also with different bias settings.
A million thanks in advance,
Tung _________________ RM100M, MTS 2X12 w/V30s, RM50 combo, 2007 Music Man LE JP6, Sterling Music Man JP50 ,81 Gibson Les Paul Pro, 80 Gibson ES-175, ESP LTD Super V, Fender Tele Joe Strummer, Fender SRV Strat,75 Fender Strat, Godin Multiac nylon.
Joined: 31 May 2007 Posts: 474 Location: Overland Park, KS
Posted: Tue Jul 17, 2007 9:25 am Post subject:
Hope this helps...
1) The amp should be on, standby in the “PLAY” position and all knobs all the way down.
2) Turn the meter on and set for reading DC millivolts. Consult the meter instructions for how to do this properly. Since all
meters are different it is extremely important that you thoroughly understand what you are looking at on the meter display.
3) Insert the Black (Negative) meter lead into the panel hole labeled “COMMON”.
4) Insert the Red (Positive) meter lead into the panel hole marked “TEST POINT 1”.
5) You typically will observe a reading between 25mVDC (25 millivolts DC) and 45mVDC (45 millivolts DC). Some meters may
read .025 volts to .045 volts. Be sure you understand what your meter is telling you.
6) With your screwdriver, turn the “BIAS ADJUST” control to obtain the proper reading for your tube type from the chart
below. Write this number down.
7) Next, move the red meter lead to the hole labeled TEST POINT 2. Write down the value. Both readings from steps 6 and 7
should be within the range shown on the chart. Readjust if needed to get both tubes into the proper range of readings.
Lastly, keep the red test lead in the TEST POINT 2 hole and move the Black meter lead to TEST POINT 1. You should read
less than 5mVDC (5 millivolts DC) or .005VDC. If the reading is greater, this indicates the tubes are not very well matched. It
doesn’t necessarily mean they are defective, just not matched. If the reading is greater than 8mVDC (8 millivolts DC) or
.008VDC, we recommend replacing the pair with a closer matched set.
9) After completing the adjustments, allow at least 5 minutes for the tubes to warm up and stabilize. Then recheck and readjust
if needed. Lower settings will typically sound a bit cleaner and harder while higher settings tend to be a bit more
compressed and softer. Find a range you prefer.
BIAS READINGS:
6L6/5881 28mV to 35mV
EL34/6CA7 30mV to 38mV
E34Ls 35mV to 45mV
6550 35mV to 45mV
THANKS!! I really have to give kudos to my cut and paste skillz. W/o the help of CTRL+C and CTRL+V, I would be helpless.
Thanks so much. I just downloaded the RM100 Manual where I found your source Looking forward to setting my own bias _________________ RM100M, MTS 2X12 w/V30s, RM50 combo, 2007 Music Man LE JP6, Sterling Music Man JP50 ,81 Gibson Les Paul Pro, 80 Gibson ES-175, ESP LTD Super V, Fender Tele Joe Strummer, Fender SRV Strat,75 Fender Strat, Godin Multiac nylon.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
