Running two T2 heads midi question
80%NINJA
Is there a cable or splitter box that will switch both heads simultaneously? I am running two T2 heads and want to switch both at the same time. I can use an A/B for the inputs on the heads to send a signal to both at the same time. I just need to figure out how to Midi switch both head channels.
If my thinking is correct, you plug your footswitch into one head like normal....then you use another cable to run from the "midi thru" jack on that head to the footswitch jack on the other head, thus using the midi controler for both heads at once. RD/Rich should chime in here and shed some light on the subject.....I could be totally wrong but that seems like the logical approach to me.
Randall_Rich wins the "Smile and a Hand Shake Award" for Wednesday, Dec 19, 2007 :D His answer is correct.
RF4T2->T2 (1) MIDI IN->T2 (1) MIDI THRU->T2 (2) MIDI IN
