Randall Rg100es XP?
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps
death8350
PostPosted: Sat Dec 13, 2008 8:51 pm    Post subject: Randall Rg100es XP? Reply with quote
I just bought a Randall RG100ES XP for a 100 bucks!!!! What does XP mean?
linthat22
PostPosted: Sat Apr 25, 2009 4:22 pm    Post subject: Re: Randall Rg100es XP? Reply with quote
I don't know what the XP means, but I've owned this head since 93 or 94. The only thing I can tell is that there's a "sustain boost" switch on the front that the original RG100ES didn't have.
Of course I need the schematics for this particular head since the damned thing is not working correctly.
graptemys
PostPosted: Tue Jan 11, 2011 8:40 am    Post subject: RG100ES XP Reply with quote
The only difference between the RG100ES and the RG100ES XP series is that the sustain boost is a switch on the XP and you have to pull the treble knob on the red channel on the non XP (a switch vs pull knob). The are otherwise identical.
Led Hendriani
PostPosted: Tue Jan 11, 2011 4:37 pm    Post subject: Reply with quote
From what I read about it, the XP has a switch that when turned on does not lose as much volume as the non XP units do when pulling the tone knob for added compression.
I want to find out how I can modify the RG80 I have to not lower the volume with the tone knob pulled. I hear all I need to do is put an eq in the loop and/or a boost pedal up front and it will do it, but I would like to mod it inside if I can find out how to do it right...
graptemys
PostPosted: Wed Jan 12, 2011 8:28 am    Post subject: Switch Reply with quote
I can attest, since I have had the RG100ES XP Series since 1989, that when you click the sustain boost switch, the volume goes down just like in the RG100ES. There is a rare device called the Randall XP-3 Block Booster that when connected to the amp, will give you the same volume with all the extra crunch. They are extremely rare and go for about $150 bucks when one shows up on ebay or a vintage guitar store.
MikeKing
PostPosted: Thu Sep 22, 2011 1:22 pm    Post subject: Reply with quote
Do you own one of the XP3 blocks. Im bring to find someone with one I can get a Picture of the inside. I know there is nothing more than a Cap, Resistor and a LED in it. I have one someone took apart and want to put it back together.
Ingolo
PostPosted: Thu Apr 25, 2013 9:32 am    Post subject: Randall XP-3 Reply with quote
I still own one of these babies. Back is gone, all innards intact. Works.
let me know if interested.
Post new topic   Reply to topic    MTS Forum Forum Index -> Other Randall Amps All times are GMT - 6 Hours
