RM4 question?
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules
Dirt_Mopar
PostPosted: Fri Sep 15, 2006 10:50 am    Post subject: RM4 question? Reply with quote
Can you power these with a solid state amp? I have one is why im asking from Pa gear.. i understand tube is perferred. Im new to this stuff. Thanks!
I play a ole randall RH100 now, Im allready a randall nutt!
ned
Site Admin
PostPosted: Fri Sep 15, 2006 12:24 pm    Post subject: Reply with quote
No reason why you can't power the RM4 with a solid state amp.
Grail Tone - Amp Settings
My Rig: Egnater Mod 50 1x12 Combo w/ VX and SL2 modules
FX: Digitech GSP1101, RM4 w/ SuperV, JTM45, Plexi, XTC, KH2, TB
Personal Web Page
Scott
PostPosted: Fri Sep 15, 2006 12:30 pm    Post subject: Reply with quote
You could probably run it into the effects return on your Randall head Too
NC_Charvel
PostPosted: Fri Sep 15, 2006 2:03 pm    Post subject: Reply with quote
I got my RM4 with a Randall R2/200 solid state poweramp and it is INSANELY loud!!
I think it's basically the power section of the amps Dime designed with Randall.
I have no problem with it other than it being insanely loud....
It will work fine Shocked
View user's profile Send private message AIM Address
3 Mile Stone
PostPosted: Sat Sep 16, 2006 9:59 am    Post subject: Reply with quote
Definately would work. Since that amp is a guitar amp the power section is probably "voiced" a little beter than a P.A type SS power amp. I had to do this a while back at practice and I used one of those new Ibanez solid state amps. It sounded pretty good. The Randall RH 100 amp even has an effects level control. Set all your volumes at 12 o'clock, plug the output of the RM4 into the return of the efects loop and adjust the level till it sounds right. Then just tune up the volumes and tones on the RM4 till you hear what you like.
Ready to rock!
TommyT
www.3milestone.com
Fender Strat/ Les Paul>Teese Wah/MXR Custom Audio Boost/MXR Bass Octave/Mxr Custom Overdrive/Xotic BB/ Barber DD/Strymon Lex>Digitech GSP1101>Egnater MOD 50>B'man>Eganter Custom Shop 1X12
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules All times are GMT - 6 Hours
