guitarguy510
Does the bottom plate come all the way off? It appeared to be joined with the front plate on an older module I had, and I'm waiting for my TopBoost so I haven't looked at a newer one myself. Will it come off totally or only part of the way? Also, when solder an item onto a PCB (I've only soldered guitar electronics before) do I touch the iron and solder directly on the board or do I solder onto the resistor while it is in the hole? Thanks guys!
I just got it... clipped off the C7 and C13 pieces but I can't get the bottom plate to come off. Is there a trick to it? It looks like it is connected to the front metal part, so I can't figure out how to access the bottom of the PCB? PLEASE HELP!!! I was hoping to mod this and have it done by tonight so I could make sure it works!
