Top Boost Modification Help
rickgk
Hi There,
I am ready to try out the modification to the top boost module to tame the gain, but the only resistors that my electronics store have are 100k ohm 1/2 watt resistor, whereas on this site it is stated that the resistor needs to be 1/4 watt.... can i get away with using the 1/2 watt resistor over the 1/4 watt or will i not get the desired result?
Rick
Hi rickgk
There is no problem to use a 1/2w resistor instead of a 1/4w since the power rating is twice the one that's required, the resistor will be only a little larger physicaly. You shouldn't have any problem with that since there enough space on the pcb.
