Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
CC Number and CC Value
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="warmachine67" data-source="post: 160951" data-attributes="member: 3696"><p>Are each of the syn2 on the same channel or does each have its own unique channel?</p><p></p><p>Perhaps you have already done this, If they are on different channels, just add a second line in the Morningstar editor for each button and bypass the Syn you don’t need with a second cc command mentioned earlier. Repeat three times, then do the opposite for the other Syn.</p></blockquote><p></p>
[QUOTE="warmachine67, post: 160951, member: 3696"] Are each of the syn2 on the same channel or does each have its own unique channel? Perhaps you have already done this, If they are on different channels, just add a second line in the Morningstar editor for each button and bypass the Syn you don’t need with a second cc command mentioned earlier. Repeat three times, then do the opposite for the other Syn. [/QUOTE]
Verification
Post reply
Modular Amps
