Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Effects pedals between M4 and poweramp???? Help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MarcoR" data-source="post: 134200" data-attributes="member: 961"><p>Is it a ground loop buzz or a hiss? Is it just on high gain modules? Where do you have the master volume set on the M4? Where do you have the master volume on the modules? What power supply are you using for the effects and are the grounds isolated?</p></blockquote><p></p>
[QUOTE="MarcoR, post: 134200, member: 961"] Is it a ground loop buzz or a hiss? Is it just on high gain modules? Where do you have the master volume set on the M4? Where do you have the master volume on the modules? What power supply are you using for the effects and are the grounds isolated? [/QUOTE]
Verification
Post reply
Modular Amps
