Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Power Amp for Axe FX
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Stamil" data-source="post: 160836" data-attributes="member: 4249"><p>Hey there! I came across a great deal and ended up buying a cheap triple rectifier that I'll be trading for an ax FX.</p><p></p><p>Now i have a few questions regarding the power amps I should buy. The amp tech I took my triple rec to recommended me tube power amps all the way. Said they work harder, sit better in a live mix, and really push your sound well.</p><p></p><p>And a lot of others who use the AXE fx or other digital processors seem to want solid-state power amps that don't color your tone at all.</p><p></p><p>Can anyone give me any advice or tell me what I may need to know before buying a power amp?</p><p></p><p>If the cab matters at all I play out of an omega 2x12 with eminence swamp thang/eminence wizard. Playing mostly metal on this setup.</p></blockquote><p></p>
[QUOTE="Stamil, post: 160836, member: 4249"] Hey there! I came across a great deal and ended up buying a cheap triple rectifier that I'll be trading for an ax FX. Now i have a few questions regarding the power amps I should buy. The amp tech I took my triple rec to recommended me tube power amps all the way. Said they work harder, sit better in a live mix, and really push your sound well. And a lot of others who use the AXE fx or other digital processors seem to want solid-state power amps that don't color your tone at all. Can anyone give me any advice or tell me what I may need to know before buying a power amp? If the cab matters at all I play out of an omega 2x12 with eminence swamp thang/eminence wizard. Playing mostly metal on this setup. [/QUOTE]
Verification
Post reply
Off Topic
