Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM100 RF3 footswitch external power
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="9985" data-source="post: 161498" data-attributes="member: 1761"><p>PSA for anyone using a 5-pin MIDI cable and external power and external power supply on a RM100 3 button MIDI footswitch (model RF3):</p><p></p><p>The RF3's 9-12 volt DC power input uses a less common connector, 5.5/2.5mm centre positive, same as Eventide pedals. If you happen to be using CIOKS or Eventide Powermax pedal power supplies, it takes a Type 4 flex cable (the green one). Carry on...</p></blockquote><p></p>
[QUOTE="9985, post: 161498, member: 1761"] PSA for anyone using a 5-pin MIDI cable and external power and external power supply on a RM100 3 button MIDI footswitch (model RF3): The RF3's 9-12 volt DC power input uses a less common connector, 5.5/2.5mm centre positive, same as Eventide pedals. If you happen to be using CIOKS or Eventide Powermax pedal power supplies, it takes a Type 4 flex cable (the green one). Carry on... [/QUOTE]
Verification
Post reply
Modular Amps
