Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM22 into 4 ohms
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Taipan" data-source="post: 160384" data-attributes="member: 3560"><p>Hi guys</p><p>I just realized during a rehearsal I was running my RM22 into my Marshall stereo cab on 4 ohms (the amp specifies 8/16 ohm)</p><p></p><p>After realizing , I quickly switched to the 16 ohm input and found it sounded quite a bit better in the 4 ohms ( tighter , clearer less compressed)</p><p></p><p>My question is can the RM22 handle running at 4 ohm or as I suspect this will blow up the amp and dont do it ? :x</p></blockquote><p></p>
[QUOTE="Taipan, post: 160384, member: 3560"] Hi guys I just realized during a rehearsal I was running my RM22 into my Marshall stereo cab on 4 ohms (the amp specifies 8/16 ohm) After realizing , I quickly switched to the 16 ohm input and found it sounded quite a bit better in the 4 ohms ( tighter , clearer less compressed) My question is can the RM22 handle running at 4 ohm or as I suspect this will blow up the amp and dont do it ? :x [/QUOTE]
Verification
Post reply
Modular Amps
RM22 into 4 ohms
