Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM50 + G Major Midi setup
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="VitaminG" data-source="post: 152493" data-attributes="member: 2326"><p>The FCB1010 has two relay switches so you can program it to change channels on non-midi amps. You just need to tell the unit to switch the effects unit to patch 23 and the amp to channel 2 on the press of button 5.</p><p></p><p>It will require that you run two cables from the FCB, midi for the G Major and one for the amp.</p><p></p><p>I believe the G Major also has latching relays to change channels on non-midi amps, so you may be able to run one midi cable to the effects unit and write your patches to include amp channel changes</p></blockquote><p></p>
[QUOTE="VitaminG, post: 152493, member: 2326"] The FCB1010 has two relay switches so you can program it to change channels on non-midi amps. You just need to tell the unit to switch the effects unit to patch 23 and the amp to channel 2 on the press of button 5. It will require that you run two cables from the FCB, midi for the G Major and one for the amp. I believe the G Major also has latching relays to change channels on non-midi amps, so you may be able to run one midi cable to the effects unit and write your patches to include amp channel changes [/QUOTE]
Verification
Post reply
Modular Amps
