Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
syn50 cathode bias
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="hblu" data-source="post: 161860" data-attributes="member: 4462"><p>I know it’s a necrothread but just wanted to add info for accuracy — the syn-30 is cathode biased and as baron55 pointed out the syn-50 is fixed bias. Both have 6L6 pair of tubes but similar to the studio Marshall series which has 2 el34’s the syn30 is less efficient — so 30 watts with 2 6L6 compared to 50 watts for the syn50 with the same power amp tube complement. Probably amounts to some differences in tone/feel if poweramp gets pushed and means you don’t need to bias for tube changes (which could be needed for the syn50). And happy New Years to all!</p></blockquote><p></p>
[QUOTE="hblu, post: 161860, member: 4462"] I know it’s a necrothread but just wanted to add info for accuracy — the syn-30 is cathode biased and as baron55 pointed out the syn-50 is fixed bias. Both have 6L6 pair of tubes but similar to the studio Marshall series which has 2 el34’s the syn30 is less efficient — so 30 watts with 2 6L6 compared to 50 watts for the syn50 with the same power amp tube complement. Probably amounts to some differences in tone/feel if poweramp gets pushed and means you don’t need to bias for tube changes (which could be needed for the syn50). And happy New Years to all! [/QUOTE]
Verification
Post reply
Modular Amps
syn50 cathode bias
