Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Variation on clean module modification procedure....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Chad" data-source="post: 4121" data-attributes="member: 142"><p>Exactly.</p><p></p><p>Also, it appears they soldered the second resistor in from the top, which should be easier to do as it looks like a really tight fit to fit a soldering iron tip in between the bottom of the circuit board and the bottom plate. I know people have done it, but wow that looks like a tight fit.</p></blockquote><p></p>
[QUOTE="Chad, post: 4121, member: 142"] Exactly. Also, it appears they soldered the second resistor in from the top, which should be easier to do as it looks like a really tight fit to fit a soldering iron tip in between the bottom of the circuit board and the bottom plate. I know people have done it, but wow that looks like a tight fit. [/QUOTE]
Verification
Post reply
Modular Amps
Modules
